- Joined
- May 20, 2024
- Messages
- 1,613
- Media
- 935
- Reaction score
- 1,319
- Location
- Austintown, Ohio
- Military
- US Army Combat Veteran
Was down to -15 here 2 weeks ago, and zero issues.
@CarbyteIt appears the PowerStep module is only using the OBD port for power, so connecting it in parallel with Carbyte should not cause any issues.
In fact, Carbyte can work alongside many different OBD connected devices through a splitter (Zee921, another user on this forum, is using it alongside dash cams). The only exceptions are devices using the OBD port to communicate with the truck's systems -- other OBD connected disablers, OBD scanners, and OBD vehicle trackers will all interfere with Carbyte’s function.
You only need to install the latest version, as each update includes all of the previous improvements.
@Carbyte
If using an OBD splitter, will the Carbyte unit conflict with the Banks Pedal Monster unit since it also requires a connection to the OBD? Banks was able to confirm no conflict with the Range RA007 DFM disabler since it plugs directly to the ECM, however they were not 100% sure of with the Carbyte. Thank you.
Not sure if anyone ever replied so sorry if this is duplicative but I made the same mistake. The unit itself works as long as its plugged in; its 100% plug, play, and forget. You do NOT have to connect to the app for it to work. However, you DO have to re-connect to the app every drive if you want to see the info/data on your phone. Obviously, if I'm wrong, someone please correct me ....but I made the same mistake of thinking not being connected to the app meant the unit was not working and was informed of my mistake in a different thread.I have been following this thread since day one. Thanks to the moderators for not removing this as spam, and thanks to Carbyte for reaching out in this forum.
After looking into the device, I pulled the trigger, and mine arrived two days ago. I installed it that day, and everything worked as advertised. Later that day I saw the firmware update post, and immediately updated. After two days of driving, I have found everything to worked perfect.
I do not like the start/stop feature of my new 2024 Yukon XL AT4, and I have been told for years that the AFM programming is responsible for lifter failures in several GM engines. My son graduated from college last year, and I gave him my six year old Yukon Denali with less than 80k miles. Ten days ago the lifters on that vehicle failed. He is currently working through it. I don't expect Carbyte, or anyone for that matter to guarantee that the device will prevent damage, but for the price I am willing to give it a try. Even my dealership mechanic says that the AFM is extremely problematic.
I am sure that I am doing something wrong, but I have found that I have to "reconnect" the device every time I get into the vehicle. If there is a way to configure the device to automatically reconnect every time I get in, that would be perfect. "Fire and Forget". Please advise. (yes my phone is always with me)
Thank you all for your comments, and thanks to the forum and Carbyte.
I ended up taking my Carbyte unit out and going back to the Range product. My fuel economy completely tanked...got down to 13.2 mpg before I decided to pull it out. Back with the Range product now and my fuel economy is back up to 15.7 mpg...and that's doing all the same type of driving. Both products do the same thing essentially, but I can't use something that kills my fuel economy so much.
Why did you have a Carbyte is you already had a range? How would one product keeping all 8 cylinders active get better or worse fuel milage than another product that keeps all 8 cylinder working ? Your review make no sense at all. Both devises do the same thing, one is not going to get better or worse fuel milage. They turn off auto start/stop and turn off the DFM if you choose to have both turn off, these do not have anything to do with tuning that might affect milage. Its either on or off....I ended up taking my Carbyte unit out and going back to the Range product. My fuel economy completely tanked...got down to 13.2 mpg before I decided to pull it out. Back with the Range product now and my fuel economy is back up to 15.7 mpg...and that's doing all the same type of driving. Both products do the same thing essentially, but I can't use something that kills my fuel economy so much.
While the two devices are similar in that they activate all 8 cylinders and disable the DFM, the way they go about doing it is different. The Range product (which I had purchased first before Carbyte came out with their product) plugs into your ECM in the driver's side front wheel wheel while the Carbyte plugs into your OB2 port.Why did you have a Carbyte is you already had a range? How would one product keeping all 8 cylinders active get better or worse fuel milage than another product that keeps all 8 cylinder working ? Your review make no sense at all. Both devises do the same thing, one is not going to get better or worse fuel milage. They turn off auto start/stop and turn off the DFM if you choose to have both turn off, these do not have anything to do with tuning that might affect milage. Its either on or off....
