hdrolling
Well-known member
- Joined
- Jan 13, 2025
- Messages
- 231
- Media
- 136
- Reaction score
- 359
- Location
- Grays Creek NC
- Military
- Retired Army
Interesting. And my main reason for wanting one was to be able to hear the active exhaust at all times, and to read and clear codes. So it sounds like I have the right tool for my needs.While the two devices are similar in that they activate all 8 cylinders and disable the DFM, the way they go about doing it is different. The Range product (which I had purchased first before Carbyte came out with their product) plugs into your ECM in the driver's side front wheel wheel while the Carbyte plugs into your OB2 port.
One of the nice things about the Carbyte product is that it truly disables DFM once you've reached about 40 mph; while the Range product allows for DFM to be enabled if your engine isn't under power (i.e. braking, coasting, etc.). Additionally, the Carbyte allows you to scan codes, which the Range doesn't.
Range does specify on their site that it's completely normal for certain model trucks to still have the DFM enable, which unfortunately my 23 AT4X does that when coming to a stop. I liked that I would no longer hear that "rumble" of the DFM kicking in when coming to a stop sign with the Carbyte, but for whatever reason, it absolutely killed my fuel economy. My guess (and this is completely a guess), is that when your engine is not under power, the fuel economy doesn't jump up to the 99 mpg, but instead continues to use fuel. Whereas with the Range product, if the engine isn't under power, it's also not using fuel.
I agree with you that both "should" give the same results, but after months of using both, there's a clear difference in the results...and I'll stick with the product that gives me the best of both worlds, which for me is decent fuel economy AND running on all 8 cylinders when the truck is under power.
If I was after fuel economy on a 6.2L I would leave it stock out of sport mode with the DFM and auto start/stop enabled.
The other perk is if I have an issue and need to be towed to the dealer I can just reach down and unplug it and put it in my pocket, same if I need to go in for updates or recalls/warranty work. And then just plug it back in before I leave.
