I have the Toyo ATIII x12.50 X17 and wish I would have gotten the Toyo ATIII x 11.50 X17 because the 12.50'S rubbed very badly. Had to do a lot of trimming and finally installed Bilstein 5100 Adjustable front shocks - Ready Lift 1.75" leveling kit w UCA's, plus the factory lift already on the truck and now it is a bit higher than I wanted. :( The narrower tire is a good choice. (y)
Yes agree poopster and after all of the reading I've done I may even go with the 285/75R17. I currently have a '19 Duramax which I don't need anymore and thinking I may be a little bit more conservative this time around. A 285 will still show a lot of sidewall and at 59lbs probably better suited for a 1500 front suspension.
22x12 Fuel Assault (-44 offset) - 35" Terra Hunters - 4" RC lift
Thanks it's Xpel Stealth PPF
@nanu108 - That Xpel Stealth looks awesome.
What are your full tire specs...looks like 35's?
What lift are you running? I presume you did trimming for rubbing reasons? Do you rub at full lock?
What are your wheel specs including backspace and offset?
Fuel Shok 17x9 -12mm D66617908445
BFGoodrich 35x12.50R17 BFG66539
ReadyLift 1.75'' Leveling Kit 66-3921
Bilstein 5100 front and rear
I trimmed alot because I put the 35s before the leveling kit. After the kit/lift I dunno how much trimming you would have to do.
Awesome, thanks for the detail! Do you rub at full lock when turning?
