2020 1500 AT4
Wheels: Method Mr305 18x9 -12 offset, 4.5 backspacing
Tires: 35/12.5R18 Nitto Ridge Grappler
Suspension: 4" BDS lift with adjustable FOX coilovers
"Needed minor plastic trimming and has a slight rub at full turn. As you can see from the pics this wheel and tire combo can be done No spacers, and the tires stick out over 1" from the fenders"
Now ideally you would have picture straight down the side as well as one right in front of the wheel.
This is not my truck, and all pictures as well as information came from:
I've posted this before but should probably consolidate in this thread ;)
2021 AT4 1500 6.2L 10 speed
stock suspension
mud flap bracket delete
minor rubbing on the right front when going fast and hitting a bump (very minor)
Black Rhino Sentinel 20" +12 offset
Nitto Ridge Grappler 295/60r20
2021 1500 AT4
Wheels: Bronze Method Mr305 20x10 -18 offset, 4.79 backspacing
Tires: 33/11.5R20 Nitto Ridge Grappler
Suspension: 1.75" Zone leveling kit with Zone upper control arms
"Zone off-road 1.75 leveling kit. With upper control arms. Trimmed the triangular corner piece in front of the front wheels on the front bumper with a oscillating saw. Sanded. Removed metal bracket behind fender liner. Drilled a hole in factory mud flap. Used mud flap bracket bolt to pull mud flap back. Installed zone UCAs and leveling kit."
Still not my rig, info came from here:
2021 1500 AT4
Tires: 33/11.5r20 Nitto Ridge Grappler
Looks great. Any pictures from the front?
Like to see if/how much they stick out past body.
Sorry man, I couldn't find any more pictures of this rig (specifically the one you requested) :(. However, after inspecting the first picture, below is what I estimate you would see of the tire if the picture was taken perfectly down the (right) side of the vehicle. The body would end at somewhere in the blue line, and everything else to the right of that would be visible (looking down the drivers side).
Sorry I'm not able to be more helpful.
Found a rig (AT4!) with the same wheel and tire seize, as well as with a leveling kit! It has slightly more useful pictures.
2019 Sierra 1500 AT4
Wheels: Fuel Contra 20x10 -18 offset in Gloss Black with Milled Spoke Edges with a Candy Blue Tint, 4.79 inch backspacing
Suspension: 2" (?) Rough Country leveling kit
"Trimmed air dam/valance, no rubbing. Aggressive stance with over one inch sticking out of the fender"
@TDCAT41 take a look at the photos below this. They might help you out get an idea of the stance. Keep in mind the front will usually stick out more than the rear.
Yet again, this isn't my rig. Info and pictures came from here:
This is a sweet rig!
2021 Sierra 1500 AT4
Wheels: Fuel Ammo 18x9 -12/+1/+20 offset (not specified, those are the ones available for this wheel) in Matte Gunmetal Gray with a Black Simulated Beadlock, 4.53/5.04/5.790 inch backspacing
Suspension: 4" BDS suspension lift. Appears to be the standard lift, not the coilover conversion.
"Minor trimming to inner wheel well plastic, still has a slight rub at full turn. 1.5 inch spacers, front and rear. Aggressive stance, sticks over one inch out past the body"
Yet another rig that isn't mine, info and pictures came from here:
When you reply in a thread...you're "subscribed" to it. You receive notifications when things update, someone posts a reply, etc. "Subbing" is an abbreviation for subscribing.
Oh okay, thanks for explaining to me! You can also get notifications without replying to a thread, here are the instructions for that:
Underneath the title, to the right hand side, there is a button that says "Watch". Click on it, and it will allow you to confirm you want to watch the thread, as well as the ability to decide if you want to receive notifications or not:
Choose if you want to get emails for it or not, then hit "Watch". Now you will get notifications!
Also, if you ever decide you want to unwatch a thread for any reason, the "Watch" button will have been replaced with an "Unwatch" button, which you can use to unwatch a thread. It will also ask you to confirm that you want to unwatch it.
Hope that is helpful!
