Just installed Cognito Elite 3” Level and HATE…
I just finally did the elite leveling kits by cognito with the Elka 2.5 for my 2024 AT4 I also got a 1” block for the rear probably could have done 2” but it’s hard to tell I do have a 1” rake still. I also am ru Ning 295 65 R20 Falken Wildpeaks AT4 and the upgrade from the 275 65 R20 a few days before I did the leveling kit it did not rub at all with factory rims.
I do love this kit and tire combo just need to figure out how to play with the DSC shock adjustment for high and low speed compression.
I also got the pitman are and idler arm reinforcement kit from cognito and it definitely made the steering tighter.
Do you feel that it could handle another 1.2" of tire width? Height of 35x12.5x20 is same height, just 1.1" wider!
295/65/20 is the largest that fits and just clears the inner liners. Depending on mfr that’s a 35.4 x 11.5.
Yes you will rub with a 12.5 on factory wheels. They will hit the liner on full turn and peel it up as it’s smashed between the tire and frame.
Depending on which Fox kit you go with, I have heard that they ride a bit stiff. If you can stomach the extra $$$, i def go with an adjustable shock…King, Fox 2.5 DSC. Of course I fully endorse the Elkas.
Yes…37” would look pimp. If i go that route, i think I’d also get them wrapped around 18” Method Bead Grip 701 HDs.
I’ve also heard the Fox shocks ride rough. If you want the best ride get Kings. The smoothest riding shock made for the HDs, it’s ridiculous.
…that I didn’t do it sooner. The ride quality of my stock 2024 HD AT4 was very nice for a heavy duty truck, but this level kit, paired with the Elka 2.5 shocks, takes the ride to a next level. I haven’t taken it off-road yet, but i suspect when adjusted correctly, it will take the beast of a truck to new heights. I was debating going with the 4” lift, the wife argued it was too much…glad she won that one. This level is insane.
What is ur Elka setting I have the same shock and can’t find good high an low setting
