2023 GMC Sierra 1500 AT4x AEV Build
Duha under rear seat storage. Fantastic product, US company. Never knew how much I would like and appreciate this upgrade. Had to trim just a little for the jack mount to fit properly, but wasnt a big deal. Install took about 10-15min.
Any rubbing on either size, do you know? Thanks John.
I personally don't have any rubbing on either side at full lock. I do have a 1inch front, and 1inch rear lift on mine. We both have the AT4x AEV so i dont see you having any issues with rubbing just on the stock height. The BFG's run a little small were as the Nitto's run bigger. With all that said, you should have no issues running a 285/75 18 on your rig.
It wasn't to bad. If your somewhat mechanically inclined, its not bad. The directions sucked, so you really need to lay everything out, and get everything aliened on what goes where. Once that is done, everything went together well.
I currently have the soft roll bed cover, curious on what everyone’s thoughts are on their diamondback cover and if they are worth it and if so where they got them from?
They are worth every penny. Best cover I have ever had. Bought mine through Diamondback directly. Only way other then to by one used from what i know.
Agree 100%. Ordered mine from Diamondback directly too and it was delivered two weeks before the truck arrived.
Thanks for the replies, now I need to find someone with the switchback style and see how they like it. Torn between the HD and switchback style
