Reverse Lights
I just got my truck back from the dealer, they installed my Putco 60” light bar (purchased thru GMC.com) and I’m very very disappointed It added almost zero additional light. I actually had to get out of my truck while in reverse to make sure the thing was even on. I’ll supply some pictures tomorrow evening but I’m not very happy. :mad:
I also have the Putco 60 light bar and not very happy with lighting up in reverse.
It needs to be installed just right in the gap; it took the dealer a couple of attempts to get it aligned. Although I rarely ever use them, the two amber lights on the rear AEV bumper are amazingly bright.
I went with these with the S2 Pro’s. Install took 5 minutes. It plugs into existing harness and fires up brighter than the factory fogs. A lot brighter than some of the other more expensive options that extend off the trailer hitch frame. I just went with the auto on for reverse and saved my upfitters for more important lighting. They have the kit in several variations S2 Sport and S2 Pro as well as diode dynamics. I mistakenly received the sports and installed them and they sent the pro’s out. I couldn’t see a difference between sport and pro through rear camera. They are brighter to the naked eye though.
Post some pics if you can.
I used the light green wire for the positive and the black wire for the negative and used the supplied T Tap connector. I also have a '24 so it should be exactly the same.
Confirmed this worked for me as well. Light green & black. '25 AT4. Thank you
