Leveling Kits
I didn’t do the UCAs my mechanic said leave it for now see how it rides because I’m keeping the factory rims and tires for the time being but let me know how you make out
What is the most common level heights - 1.5 or 1.75 or 2.0? I'm considering reducing the rear block to 1" and raising the front .75". Anyone done this? Thoughts or opinions?
That's how it starts...take a little off the back and add a little to the front. The next thing you know...
I am no expert but the 1.5" makes in level front to back and I didn't need to replace the UCAs i know if you go above that you would deff be recommended too to replace them as well but depends on your budget. 2" I assume your going to have a slight rear sag but someone wit a 2" would have to chime in for that
I installed the Bilstein 5100s all around plus a Rough Country .5 inch spacer at the bottom of the front struts to finally get the front tires to stop rubbing without having to do any trimming. Problem now is that I hear a lot of strange creaking noise coming from the front suspension mostly when I am going forward or backward from stopped and turning the wheel. It sounds like creaking, almost metal on metal. I have tightened all the bolts to spec several times now and can't seem to figure out where it is coming from. Is this normal from these trucks?
I bought the rough country 1.5 inch 2021 AT4 leveling kit about 4 months ago, ordered a '22 AT4 in April (wanted the refresh) with a 3.0 duramax. Trucks been sitting in Indiana since the 1st week of July. Found a '23 AT4 with the 3.0 duramax and decided to cancel my '22 and purchase the '23. Apparently, the 1.5 inch leveling kit I purchased will only fit a '21-22 AT4 - although he said it would probably work, but recommended I wait 2 months for the redesigned version for the '23 AT4....anyone have a '23 AT4 (not an AT4X) that put a leveling kit on....? looking for some guidance....thanks
Would be curious on RC as well as I may do the RC 2 inch with the new shocks and add one inch on the bacK with new shocks.
Curious to know if you ever did this ? How did it work out esp reducing tear block to 1”
I just got the truck 2 weeks ago. I will say that the truck doesnt need a ton to level it. Its not as bad as the F150 im coming from. Just put on new tires yesterday went with 285/70R18, no rubbing. I'm undecided on what to do. The easiest and cheapest would be to replace the 2" rear block with a 1" and might look fine. See attached pic from today.
