*LEVELED * AT4 TRUCKS - LET SEE THEM PICTURE PLEASE
IMO the 35s look too small on the truck. Thanks for the post was going to 35s but after seeing how it looks I might have to make the jump to 37s
37's required me to go with a bigger lift. Or go with wheel spacers to push the wheels out so they wouldn't rub. I didn't want to cut anything, or void my warranty. Good luck in your search
You can fit 37s on a 3inch lift but yeah you wouldn’t cut abit to make it work!
img_3076-webp.27743
I probably should’ve specified but mine is a 3in Cognito leveling kit, and I’ve got 37’s & 20’s.
Negative Ghost Rider. Just their 3in level kit, w/the Ella’s. I ordered Cognito’s Sway Bar as well to help tighten it up just a bit as well with the body roll but I haven’t installed it yet. Probably next week.
Cognito has a sway bar? This is new to me!
I’m planning doing cognitos brand new 3 inch level with the one inch rear block. Every picture or video I’ve seen with just the front 3 inch level always looks like the rear is lower.
I posted on another thread, but thought I’d post a little more info here. The shop I used decided to use the Readylift 1.75 in the front and then replaced the 2” block in the back with a 3” block. The reason was because of the canopy on the back and I tow my boat quite a bit and didn’t want the front end up in the air while towing.
It turned out really well and sits damn near level.
Very nice! Any rubbing with those 37s? I assume some trimming?
Minimal trimming, mainly on fender caps, which I replaced with the shorter caps from Cognito. Otherwise very light. Travis & The Custom Shop here in Las Vegas knows his suspension and wheel setups. He’s a smart dude. WC makes a
Bumper Spacer that I’m considering to give myself a little more room, but I’m not sure it’s necessary.
