iDash Pro no manual regen for 24/25
What I don't get is seeing it go down in real time during a Regen. Once the regen turns back to OFF then the "RG %" resets to less than 10.
I've got the LZO, and it may may not be the same on the big max but I can see the % level going down in real time by monitoring DPF SL % in addition to DPF RG %. Both will be roughly in sync as the % level increases to 100% and a regen is triggered. As you mentioned the DPF RG % doesn't reset until the regen is complete. DPF SL % will decrease while the regen is active. On my truck DPF SL % usually gets down to 6 or 7% when the regen staus goes to inactive. Driving another 4 or 5 miles gets DPF SL % down to 0%.
The distance between regens on the LZO is a shorter distance than on the big max, but they also take less time to complete so the distance I gave may be different on the HD's
v1.05.0 Release Notes (04/15/2025):
  • Transmission Gear PIDs added for Subaru, BMW, Sprinter, Audi
  • Stationary Regen on GM Global B
  • Mobile Regen on GM Global A and GM Global B
  • Theme colors added: Amber/Black, Blue Green/Black, Black/Blue Green, Grey/Red, Purple/Black, Black Ops/Red, Black Ops/Blue, Black/White
  • Min/Max logging feature added
  • Toyota PIDs added
    • 2014-2021 Tundra: Current Gear, Torque Converter Status, Transmission Fluid Temp, Engine Oil Temp
    • 2022+ Tundra/Lexus GX: Transmission Fluid Temp
  • Added prefix to serial numbers. “A” denotes primary iDash, “B” for secondary iDash
  • Bluetooth and User Interface Improvements
  • Minor bug fixes
Updated, the first flash didn't go well after the reboot the only available data was battery. Rebooted and nothing changed, reflashed and all the parameters came back. I haven't looked for the regen trigger yet but re added regen status to see if it works now.
Did you notice any other changes or features?
I have noticed that I have to reconfigure settings to Global B after the update so I can have DPFSL% show.
I didn't really play with the color settings. I will do mobile regens unless I absolutely have to do a stationary regen due to the sound.
My screen 1 didn't change but it changed the layout and fields on screens 2,3. Overall seems to work, wish they would give us oil pressure.
I'm not sure if I'll even bother with the update as I'm not seeing the usefulness of stationery regens. If the had added oil pressure I would have updated without hesitation
Is it just stationary? Does it allow manual Regen while driving with more than 90% like the 23 and older GMs?
