Just got my MX4 today and completely satisfied!!! Thank you all for the recommendations, I couldn’t be happier.
Are you still happy with your bed cover??? Any problems with water leaks??? I've been looking at the SE for my new 2023 AT4X. How did you seal up around edge of tailgate and multi pro edges??? Any help would be appreciated. ThanksI installed the Diamondback SE cover and could not be happier.
Hi, I have not had any issues with leaks and am still very happy with my cover choice, my sons are also happy with theirs. My only slight issue is with the tailgates lack of sealing. If I go through a touch less carwash since it is winter here. It comes through the left and right space where the smaller gate meets the main gate, I need to add some weather strip. If you put a light in the bed you can see it very clearly through those spaces. Reality is not much comes in so I may not mess with.
Looks great! How do you like the toolbox?Finished up install of Diamondback HD bed cover. Very pleased with the looks of this cover. Install was easy. NOTE to anyone who buys one of these, be sure and read ALL directions before you start install. The first thing you have to do is remove the OEM bed rail caps and install 4 small hard rubber shims on the underside of each rail. I also added some D shaped 3/8" weather stripping along and under the outside edge to keep dust and water out of the bed. There is also a hidden opening at the top of each front corner that you have to plug up with foam rubber to keep out dust. I also added 2 Extang lights in bed cover, frt and rear, magnetic tool holders, and side storage compartments. Also installed tailgate seal kit to keep out dust and water. First test of the dustproofing will happen when I go to West Texas.
Also intalled Nxtgen spot mirror on drivers side, works well for blind spot.
This stuff works also
3M 4298UV Adhesion Promoter
https://extrudedsolutions.com/products/ultimate-tailgate-seal-10ft
Chevy Silverado, GMC Sierra 1500 Blind Spot Mirrors — NXTGEN Automotive
Vehicle specific, custom fit blind spot mirrors for Chevy Silverado and GMC Sierra 1500 trucks. NXTGEN Automotive creates the highest quality, clearest, custom fit blind spot mirrors available. Extended View mirrors are real OEM grade glass, made in the USA and use real 3M adhesive.nxtgenautomotive.com
Truck Cargo & Bed Lights | RealTruck
Invest in a quality truck bed lighting system from RealTruck with a water-resistant guarantee and warranty. Shop today.realtruck.com
DiamondBack HD - GMC Sierra 1500 2019–up
DiamondBack HD is a hard locking tonneau made of diamond plate aluminum. It's a rugged, heavy-duty pickup truck bed cover that seals and secures your bed.diamondbackcovers.com
https://www.amazon.com/dp/B08C29P9RH?tag=at4forum-20 Step Stool to reach in bed![]()
Wingman™ Cross Bin 8
Cross Bin 8 is a storage bin under the DiamondBack that keeps the bed of your truck organized by elevating gear up off the bed floor for easy access.diamondbackcovers.com
Thanks! So far so good on the tool box. Haven't really got it loaded up with everything just yet. I has quite a bit of room and left me with a 12 1/2" space below tool box to front of bed.Looks great! How do you like the toolbox?
I think these back boxes are going to be pretty handy.I want one just to toss in a hitch and a tow strap!
I ended up going with the Lomax too. Very happy with it so far.still liking my lomax.....View attachment 3198View attachment 3199
