285/70r18s Nitto Ridge Grapplers?
Just speculating but I think you’d be fine
My 2019 AT4 has 295/70r18 recon grapplers and I’ve had no issues with them. Truck and wheels are stock
I'm considering 285/75-17 as well, and from my research, it seems that if you're running OEM wheels with +24 or +28 offset, you're good. Once you start getting to 0 or negative offset, that's where you start to get rub.
No first hand experience yet, just based on what I've seen/read online.
2024 AT4X and just switched the OEM Goodyears for a set of Ridge Grapplers 285/70/18 on stock wheels and I like these tires so much better.
Love it. How much room you got? Hoping to do 295/70r18 like I have on my 2019 at4
Room seems ok as far as I can tell, no rubbing at full lock or anything. I wanted to go 295 but have seen mixed reviews, some say they will fit, others say it rubs a little so I just played it safe with the 285's
Maybe post a pic of the whole truck. 🤷‍♂️. Gives a better perspective.
Did you get your speed/odometer re calibrated? I think I'm gonna take mine in to get it done.
No I didn’t and won’t.
I haven’t looked at the speedo on the highway while holding a gps, but I don’t think it’s more than a couple mph off if the truck is calibrated properly to the stock tires
Heck I came from an AT4 where the speedo was off 5 mph at 67 mph I just mentally knew that was the case and drove accordingly. Never an issue
Mine is 2-3 mph off with the 285/70's I just installed. I'm more concerned with the odometer vs the speedo. Not a huge deal but I do like it to be right, especially given the cost of this truck.
285/70 Nitto Ridge Grapplers. So far so good. Fuel milage is hanging out around 23.5ish on interstate, fingers crossed mileage only goes up w/ additional miles.
