Useless Fog Lights
Ah, so they aren’t SAE/DOT approved. Makes sense. The glare would blind people.
Yea it would be. But the factory are so useless that having these on the roads I use sometimes that are full of deer it's nice to have. So I'm glad they are on the factory switch so it's easy to turn them on or off when I need to if someone happens to be coming at me in the other lane.
Great light output for fog lights but also probably wouldn't use them in high oncoming traffic areas.
Sweet. They look like they may be aimed a little high, but I'm assuming you checked that. Or maybe it's because of the non-SAE/DOT approval.
Non sae/dot plus this picture is also slightly uphill.
So I’ve spent the last almost 3 hours messing with these lights. This has been a total pain in the ass install. I ended up taking off the crossmember from the corner of the bumper with a 15 mm socket and that helped a lot. AEV can kiss my ass with their T-15 head screws.
So after getting them on, and then aiming them as far down as they’ll go (the top of them is touching the flange on the bumper itself, so they can’t be tilted down anymore), they are still too high. They are shining higher than my low beams and don’t have a strong horizontal cut off. So now I’m going to have to take them off again and put spacers on at least two of the three (if not all three) bolts to get them further away from the bumper bezel so that I can then aim them down further.
It’s such a pain in the ass getting your hands behind this bumper to do this mod. If I knew it was gonna be this much of a pain, I don’t think I would’ve done it.
Update: I used a 1/4-20 nut as a spacer and it worked perfectly. I aimed them low enough not to blind people. But way too much time for this mod. Yes, the light is better, but it’s not awesome.
Is there a difference in the aev front bumper for the 23 to the 25 that these wouldn’t work?
No. Mine is a 23 and they fit fine.
