STEERING STABILIZER
I could be wrong but I'm not aware of any steering stabilizers for the 1500 truck or SUVs. If memory serves me right, most of your steering system is electronic anyway (the rack) and isn't fully based on the hydraulics of a pump with fluid like the HDs, meaning your computer gets to control your steering input just right.
These stabilizers are only for 2500+ to include the old 2500 suburbans which are based on the truck frame wise.
You are correct in that my 1500 AT4 has an electric powered steering setup. Good to know this isn't something I need/should look into further.
circling back. so my kryptonite fox stablizer kit induced a slight, but very noticeable pull to the right. it had, i feel, too much of a nitrogen charge. I released some nitrogen (too much) and rendered the stabilizer essentially useless. hence the need for a new one. I went round and round trying to figure out which one to use that would be compatible with the kryptonite bracket. I ended up back at kyrptonite and bit the bullet for a new fox one.
well, the new fox stabilizer has zero pull to it. truck drives straight. bump steer is gone again.
this one must have less nitrogen charge than the first. it is the exact part number.
