CHRISONELUNG
Looking to purchase the Kryptonite steering stabilizer kit. Does any one recommend the Fox Shock over the Bilstein. Also, are there any other kits I should look into first over the Kryptonite kit?
I thought I had read that some where along the line about the Fox shock thank you. I’m not a fan of Rancho stuff but I’m glad to hear positive feedback back. Thank youi have the kryptonite kit with fox. nice unit. i've had them on my last 2 trucks as well, except used the rancho stabilizer.
the fox makes the truck have the slightest pull to the right though
I don't recall hearing it about the Fox's, but definitely the Bilsteins.I thought I had read that some where along the line about the Fox shock thank you. I’m not a fan of Rancho stuff but I’m glad to hear positive feedback back. Thank you
That’s interesting, I haven’t come across that in anything I’ve read about the Bilsteins, but it sounds like you’ve had some firsthand experience with it."
I put the Rough Country V2 kit on my 24 AT4. When you bolt the bracket to the crossmember you'll want to unload the torsion bar on that side so have the torsion bar unload tool ready. The one bolt where the bracket goes needed to come out completely in order to mount the bracket. I put a socket extension in the hole when I pushed the bolt out just to make sure the holes didn't get misaligned. Also, I had the Bilstein on a 2019 Chevy 2500 and it caused it to pull slightly to one side...not good. The RC V2 does not do that, seems to be a quality shock and the bracket is heavy duty, and it's very reasonably priced.Looking to purchase the Kryptonite steering stabilizer kit. Does any one recommend the Fox Shock over the Bilstein. Also, are there any other kits I should look into first over the Kryptonite kit?
Thank you, I ended up ordering the new Kryptonite Fox kit. I talked weith their engineering department and supossedly they collaborated with fox to produce an actual steering stablizer with half the pressure and a new style bracket specifically for the new fox with zero pull. I will give some feed back on here after some miles on it.I put the Rough Country V2 kit on my 24 AT4. When you bolt the bracket to the crossmember you'll want to unload the torsion bar on that side so have the torsion bar unload tool ready. The one bolt where the bracket goes needed to come out completely in order to mount the bracket. I put a socket extension in the hole when I pushed the bolt out just to make sure the holes didn't get misaligned. Also, I had the Bilstein on a 2019 Chevy 2500 and it caused it to pull slightly to one side...not good. The RC V2 does not do that, seems to be a quality shock and the bracket is heavy duty, and it's very reasonably priced.
