Run 35” tires with leveling kit
This is what I put on my 2022 AT4,
Icon Alloys Compression 17x8.5 +0mm wheels w/ Toyo Open Country A/T III 35x12.50R17LT tires I purchased from Custom Offsets. I had to do a lot of trimming and finally installed Bilstein adjustable shocks (set on highest lift), Ready Lift w/uca's, removed the mud flaps and I still have some very minor rub on the driver's side wheel well liner. That lifted the front several inches but then had to change the 2" rear block to a 3" block. Now the rear is about 3/4" of an inch higher than the front. Then I had to install the Aries retractable steps because my wife had trouble getting into the truck. The truck looks great but is a bit higher than I wanted.
Do you happen to know your measurement up front, center of hub to bottom of fender? Like the leveled look you have, I still have just over and inch rake...
