Reverse Level?
How did you get a 10" wheel with that offset under it? Any rubbing to speak of? I put 1.5" spacers on my stock wheels and tires to get a lil poke and it rubbed like crazy in reverse at full lock. I even cut where it was rubbing on the mud guard and it still rubbed, so I took the spacers off.
No rubbing whatsoever. The stock size tire probably helped a lot with that. I did spend quite a bit of time with online offset calculators to hope that it didn't rub. I wanted the tire to be fairly flush with the fender and my no closer to the inner suspension, which I accomplished both. Maybe I just got lucky. A larger tire probably would have given me issues. I can't remember all the particulars, but I compared these with the stock, and I think the inside remained about the same, and the outside was came out to the fender, maybe a touch more.
Edit. If I remember correctly, the inner might have been a whisker closer, but the outer only stuck out maybe an inch or more.
I’d like to run a 22x10 TIS wheel with +10 offset on a reverse level. Can you tell me your tire size and brand so I can do a little research! Cuz I am thinking of doing a mud flap delete and do not want to rub or cut at all. Thanks for the help it’s much appreciate
I think it's a 305-45 r 22. Here is the tire I bought, mainly because they were cheap. I have been pleasantly surprised though. Very quiet for an aggressive tire.
Awesome thanks! And you don’t have any rubbing or anything! And not running spacers correct?
Would you ever send me a picture of your block setup under the truck! I’m just curious about a couple things and pictures would answer them all!
This is the best I can do while parked at work. I can grab more later if you need something more specific. Let me know if you have any questions.
