Got a few things installed
so you went from the 7way up the side of the bed and drilled a hole in the bed and put the switch?
Bed already had a factory hole. I just enlarged it to fit the switch. I have the gooseneck prep. Bed has a 7-way plug about a foot away. T-tapped into that harness.
Where did you get the truck bed light switch? Is it integrated into the existing lighting or did you tap into wires?
Only tapping required was to get power from the 7-way 12v. Other than that, the kit uses factory connectors...
How hard is it to get your HK out, and does it hit on the bottom left side of the business end? I have the identical toy- bad to the Bone!
How hard is it to get your HK out and does it hit on the bottom lft side of the business end? I have the identical toy- bad to the Bone!
If'n you mean removing, not at all. Your hand falls right to it with plenty of clearance and it is held by a magnet. Muzzle does not contact center console or floormat. A non-compact would. They also have a plate that would allow more adjustment. With the seat all the way forward and down it will not hit grip.
Can I get your thoughts on the rear under-seat storage? That’s one of my top accessories I think I would like but haven’t spoken to anyone that has it? Thanks
I really like them. The covers are easily removed, if you need two hands to load or unload items. A person can pack alot of stuff in them.
Love the storage accessories in my 2500HD AT4X AEV and had included all while ordering the vehicle.
I know we use these spaces differently but in the the rear passenger underseat storage I store emergency triangle/flares, cleaning cloths and detailing spray and on the larger other side, OEM Jack/brace/etc., a 36" breaker bar and log wheel nut socket, a small tool kit, a portable electric air pump, a 12,000lb tow receiver hitch plus OEM spare TPMS and Engine block heater cable.
The first aid kit is stored in the rear passenger seat backrest space, the other side is empty.
Nothing is stored in the console safe yet but glad I have it; I need to find a small gold bar or two to put in there.
Great, exactly what I wanted to hear. I’m going to buy that and the counsel safe. Thanks for your response.
U
All good feedback I wanted to hear about both the rear under-seat storage and counsel safe. I plan to get the consolevault safe when it is back in stock. I can’t find any that come with gold bars.
I also plan to get the exterior keypad added and then I can lock my keys in the safe inside a faraday bag “I think”. (To block the key left in vehicle signal).
These Builtright seat back storage bags are handy for items that are too small for that area...
