Auxiliary lighting switches
Anyone using the AuxBeam switch panel setup, is your truck a 1500 or 2500? I’m looking to see which battery you used on a 2500 annd how you hooked it up and where you mounted the Auxbeam fuse panel.
I don't have an Auxbeam, but I connected my wiring to the auxiliary battery
20240902_225957134_ios-webp.10177
Do any of these have carplay interface? I know the Garmin one does.
The garmin is the only one that I know for sure. Switch Pros and SPod have apps that they say can be used for controlling but I haven’t used them and dunno if it works on carplay.
My auxbeam has bluetooth and an app, but that’s just to configure the control panel.
1500 here, I also mounted my auxbeam controller in the dead space between the fender and the body structure on the passenger side. It’s adjacent to the factory fuse box and the wires come up from below for a clean look.View attachment 25102
For anyone looking at the switch pros, SDHQ makes a cowl mount that I think looks pretty clean: https://sdhqoffroad.com/products/19...ower-module-mount?_pos=4&_fid=6a188a040&_ss=c
How did you bolt it inside that fender? Rivenut?
I got the OE upfitter switches installed in 2025 AT4x. Clean but are the switches live and how does one access the wires to connect devises?
Do you have a pic where they are at on the dash? I have a 24 AT4 and was told that I would have to cut out my dash somewhere to mount the switches.
