bookemdanno
Well-known member
Just looked at mine...dealership put the AEV rim facing down when they put it back up. Guess I'll be reversing that tomorrow!
It’s not that dealers don’t care, they follow the norm; the AT4X is a different animal.Just looked at mine...dealership put the AEV rim facing down when they put it back up. Guess I'll be reversing that tomorrow!
I should have checked sooner tho...A clue was that they had my rear tires set at 70 PSI when I picked up.It’s not that dealers don’t care, they follow the norm; the AT4X is a different animal.
Please look at my post #18.It’s supposed to be face down… RTM
Thanks for the heads-up.
I ordered one. The seller contacted me and asked for vehicle details and rim size.
I'll post my observations.
Yes. It was a total flop. Center section was too small to have the winch "hook" to fit through.Any update on the spare cover?
Be aware an AT4X AEV spare is supposed to be retained face up, unlike standard spares. I rotate the spare too; I had Discount Tire add a TPMS to it; I did not use the trailer TPMS sensors which I still have. I also purchased an inexpensive TPMS sensor reset tool from Amazon. TPMS sensors need to be reset following rotation; at least mine did.
Darn! Was hoping it would be more promising. So the wheel spacer will insert between the wheel and “hook”?Yes. It was a total flop. Center section was too small to have the winch "hook" to fit through.
I'm now in the process of getting a wheel spacer delivered, to use as a shim so the winch won't bottom out.. I'm using a 1½" thick spacer with a 130mm hub bore diameter.
The bore of the spare cover is 3". There is not enough metal to cut the inside diameter to 5".
That's my plan. I'll use a couple of the included lug nuts to secure spacer to the inside of rim. 1½" will be more than enough "shim".Darn! Was hoping it would be more promising. So the wheel spacer will insert between the wheel and “hook”?
Wondering if a round plastic disk, similar to flop cover could be secured with long zip ties that wrap around outside of tire through center. Some genius should figure it out but not enough demand for commercial.
