AEV clearance kit with 35s
Thanks for your post. I have been looking into this as well! I just got the AT4X standard package and was looking at purchasing the Salta Wheels, or something with a positive offset. I’m trying to run 35 12.50 R17 Toyo RT trails with as little poke as possible. Obviously clearing the control arm is the biggest issue. I have been looking at going with a kit from Peak Suspention but I have not pulled the trigger yet.
Are your wheels the stock AEV wheels with the 26mm offset? Did you do the entire kit yourself? What did you use to prop the truck?
I also have a AT4X
I am curious if the AEV 35-in Tire clearance package works on a stock 2026 1500 Diesel at4x with stock rims. What else should be done and what else needs to be done for correct operation. If I have to change out to AEV rims exclusively so be it but I sure would like to be able to use my stock rims and put dedicated winter tires on the GMC stock rims either stock tire size or 35s as I did with my second gen Raptor.
The AEV kit will work on a normal truck but the inner fender liner cutout on the front of the tire is meant for the AEV bumper. The rest will bolt right up.
Thanks for the info, I do have an at4x and for 2026 it comes stock in Canada with the AEV bumper. I'm more Curious right now if the stock GMC rims that come on the at-4x are fine. I've read somewhere that the offset , bore and stuff is different on the at-4x with the full AEV package including rear bumper extra skid plates and cosmetic interior , so I just want to make sure I could use GMC stock rims with 35s on this aev 35-in package with no issues
