3.0 Duramax Oil Catch Can Install
Do you have any of the catch can kits available? Would like black if possible. I have a 2024 Silverado with the 3.0 Duramax engine
i ran out of black ones but i just ordered more of them and hoping to have them by Friday. I can ship out a kit the following day from when I receive the oil catch cans.
Do we need this in our LP5?
It wouldn't hurt. Best deal is the VSE pvc relocation kit. If used correctly there will be NO blow-by going to the turbo intake horn! 😉
And as a bonus it moves the oil fill neck closer to the front and won't break.
I concur with germarsh, I’m a big believer in having a catch can on any vehicle that has a power adder. Any power adder will push air pass the piston rings and valve seals, this causing oil and condensation to be push to the pcv valve and into the turbo or intake. That then causes oil build up in the turbo, intake, intake valves, and injectors. I could go on about why I believe that a catch can should be used.
I’ll leave you with this, do you like to have carbon build up on the intake valves, injectors, and a clogged catalytic converter in the long term of owning your truck? Thinking about the cost of pulling your head to have valves cleaned, injector and/ or catalytic converter replacement. Plus other components such as sensors.
For the limited driving I do, I don't want to spend 400 on pvc relocation; very much doubt I'd be changing oil, 99% of the time its going to the dealer. Having said that I changed oil and filter on my Mercedes weekend before last, only because I have the oil extractor, oil and filters. It all started when I frequently travelled from south NJ to queens NYC and did significant mileage; oil change on the Benz was recommended every 10,000 miles which was done at the dealer, in addition I did my own oil change at 5000 mile interval, hence the oil extraction kit and oil; it takes 9qt oil.
A New Listing has been posted on EBay and there’s only a limited quantity available. Also, if you’d like to save $30-$50 on this kit then send me a message. Thanks
Black catch cans are Out of stock. Only have Polished, Red, and Blue in stock.
Thank you to those who have purchased a kit.
Currently have the EBay listing as Sold out, but for anyone interested I currently have One Kit available and ready to ship. I will also have more kits built in the upcoming month.
I'd like to pick up one of these raw or black. I tried to DM you but there was an error. Maybe because I'm new?
