3.0 diesel fuel additives
50 mpg…maybe downhill coasting. There’s no way that’s sustained. Best I’ve got is 30.7 for 25 miles.
It’s good mileage but let’s not get carried away.
Also, I don’t think the 26mpg posted is for an AT4.
I agree with you I find it hard to believe-just makes me wonder. AT4s advertise 22-26. At least that’s what my window sticker said.
Keep in mind when you change tire size. It also affect odometer readings. You might be traveling little longer than odometer reporting. Do about 100 mile trip with GPS and find out odo reading difference. Mpg loss is not as bad as it looks.
Yea, I am running 35x12.5's and I find the odometer and speedometer are about 5% lower than stock size tires.
I run hot shots and always feel like my truck runs a lot better then if I would forget to use it. I also noticed that once I went to 34.6 inch tires I went from 25-28mpg to getting at best 25mpg. And that’s after correcting speedometer with the idash.
Without a fuel conditioner, I get slight injector knocking at around 1500 RPM light throttle. I guess a lot of folks have this issue but any fuel conditioner works. Took a few takes to really get rid of the knock - ACDelco worked the best for knock but being $20 per fill is just insane. My dealership told me no one buys that stuff but when I told him it took away the knock he didn’t believe me.
Same. Now that I had my truck for 45k miles I can tell there is a difference after not using it for a while compared to when I a
do add it. More pickup for sure .
