GrayWolf AT4X
I recommend getting away from the 0w20 CAFE crap water like oil in the 6.2. I run Mobil 1 syn 5w30 with a Wix XP filter, 5w30 is the same weight the General runs in the 6.2 everywhere else in the world but here in the US because of gov't CAFE regulations. Thicker oil also helps increase the oil pressure slightly which is never a bad thing. My 6.2 runs 30-60 psi when hot and above 60 psi when cold so it's not the oil pump being unable to lubricate properly like some say. Like others have stated on here that run the 5w30 it runs quieter, cold starts are quieter for sure. Seems like the slightly thicker 5w when cold hangs around better on all the components in the top end and bearings on the bottom end. I always change my own between 3k-5k mi. max or 6 mos. and drain the factory fill between 500 -1000 mi., I changed at 500 on my '26 AT4X 6.2. I had a '23 AT4 6.2 and did the first change at around 1,000 and never had an issue for several thousand miles before trading for the '26. I never did the recalls on the '23, just let the dealer deal with it when I traded it. I think the engines turning bearings after they switch to 0w40 is because the damage has already been done with the 0w20. I also use an Auto S/S defeat module at the battery since new and run in manual mode never above L5 in town or L9 on the hwy to keep out of DFM mode as much as possible, L9 is only 200 rpm more than 10th. Also run an Airaid CAI that uses the factory box (for coldest air) and a K&N oil catch can. I think the only reason GM uses 0w20 in new and replacement 6.2 engines is because then they would be legally admitting that the 0w20 is too damn thin if they switched all to 0w40 and they would then be on the hook for the 1M+ 6.2's being investigated by NHTSA. They are now also running 0w30 in the new 5.7 and 6.6 engines so they know. My two cent...
