Well....I guess there is a first for everything.....I remounted those side steps last night, positioned them slightly different than the first time I installed them and no noise currently on my way to work. I made sure to snug them down to the body pretty good with a couple extra ugga duggas with the 3/8" impact..If you the do the same thing I did make sure you understand the amount of ugga duggas needed or you will strip threads on the body and have a bigger issue on your hands
If you have similar noise issue I do and it's coming from one side or driver side I would check the following in this order:
(1) Coolant Reservoir Tank - 2 bolts holding that reservoir on and factory sometimes doesn't tighten those down very well
(2) Side Steps - unbolt the bracket that mounts to the body, reposition slightly and snug that SOB down so it limits as much vibration as possible
(3) Check suspension parts over and make sure bolts are tight and no loose ball joints or end links, etc.
I will keep everyone posted over the next few weeks on whether the noise comes back or not. If it does and I can trace it to the steps for sure then I will probably make some rubber washers to place in between the body & bracket to reduce vibrations. Hope this helps anyone with similar issue as mine.
