Short antenna
Did you fully replace the red emblems or an adhesive overlay? Can you share where you got them emblems and the process for replacing them? Thanks
You’re asking for a lot…but here it goes.
I replaced everything with new emblems and badges. I got them at Shopchevyparts.com
The grill was the most complicated as I didn’t want to have to remove it. Ended up using my dremel tool on the red part to cut a slit in it, then I pulled the red portion out to access the clips for the chrome. I was then able to pop the chrome out and snap the new black/chrome pieces in. It did destroy the red/chrome emblems but I was ok with that.
The rest I masked the area around the emblems for proper location reinstalling…and then doused them with 3m adhesive remover and pulled them off. Used some braided fish line to saw through the stubborn adhesive areas.
It’s fairly simple if you just take your time.
Here’s some pics
Great thanks for the tip with the dremel
use the small cut wheel and slice though the red, then take a small flat screwdriver and pry the red out. That gives you access to the tabs and yoi can free the chrome portion. It’s not sexy and actually quite destructive but it works.
