NEXTGEN Drivetrain valve body swap
I c
Have you tried to do a reset/relearn with a scan tool?
I can clear codes but I do not have the ability to put it in to relearn. N and D both go forward and R is definitely fighting to move so something is not right. The truck did try to run properly at first. I really think a solenoid is stuck but didn't have the give a damn to drop the pan....again.
I c
That might be the issue. If you can get access to something like an x tool d8bt (what I use) there is the option to go into relearn. If the codes clear then the issue is software not hardware. I couldn't clear any codes with my old VB in place. Codes only cleared when the new one went on.
Also what fluid fill procedure did you use?
I filled it until it ran out of the fill plug, then had my wife start the truck. Then I pulled the check bolt and filled until that ran out. Had her cycle each gear, including L, and then topped it off. Have not checked fluid since my very short test drive but it took about 17qts.
Just to clarify - you filled until it came out of the standpipe hole correct? Not the fill on the side of the tranny.
Are you running a stock pan?
Initially I filled it to the fill port to maximize the amount of fluid available to the pump, afterwards it was filled to the stand pipe, stock pan.
That might be the problem - too much fluid. Not a stuck clutch.
With the truck OFF - take your standpipe bolt out. Let it drain completely until it starts to trickle out - not a steady stream. Turn the truck on. Watch the fluid. If it doesn't trickle out - add more with the truck on until it starts to trickle out. Once it starts to trickle out - run through the gears. I paused at each for about 5 seconds and I did not go to L. Just D. Once you finish running through the gears (with the standpipe bolt out), look at the fluid. If it's not coming out add more until it does. Then close it up and go on a test drive.
That's the nice thing about the motive powerfill is it keeps fluid added unless you turn the handle to the off position.
There is a possibility that if there is damage to the VB, that the damage is irreversible and it will need another swap out. I also was worried about the tranny running dry but as long as you aren't driving and adding fluid you will be fine. Don't turn the truck off at any point once it's on.
I'll definitely try that.
I tried moving it the last 2 mornings just to see what happens. It'll go into reverse like normal but after it rolls about 10ft it'll lock up (stops abruptly and you can hear the engine load increase, like a trans brake). In N it'll go forward. Putting it in park the load releases and does the same thing if put back into reverse.
NG thinks there may be a warped clutch but I didn't believe that, if a clutch was stuck it wouldn't release in park or engage itself in reverse.
Dropped roughly 2qts out then cycled through the gears. Still had a small dribble so I tried moving it. Same results, R will bind up and N is forward. Last code I had before I cleared them was solenoid A stuck on. I think I'm going to drop the pan and see if I can cycle that valve.
I wish I could get a hydro circuit diagram, does anyone know if my symptoms line up with the A solenoid not being fully closed?
It's possible that the damage done is irreversible. You should try to swap out this valve body again and re-try the fill procedure the way I described it.
I'm leaning toward this being a valve body issue caused by too much fluid. If you look up the code it was giving you online and let Google do the work it will tell you if that is consistent. It was with my code.
All my research is pointing towards stuck valves in the vb. I can't wait another week for them so I'm going to clean it tonight and see what happens
I would agree it's the VB. Keep us posted
I'm just going to get the transmission replaced. Cleaned the vb and got the same results again, however I no longer wish to work with NG.
THERE'S STOCK VALVES IN MY VB. I have nothing good to say about ng at this point and I'm completely convinced the first vb they sent me was faulty and cost me my transmission. I know there's no way to prove that in court. But again MY WARRANTIED VB HAS STOCK VALVES. This just proves to me whatever they're doing fails and the fix is to go backwards to stock components. So beware anyone that's got a warranty replaced vb most likely has stock valves too.
Sorry man. Yeah it's very possible that the first VB did irreversible damage. I'm glad I went back home as soon as I got a violent jolt.
I'd be curious to see what they say if you send them that picture
You should at least get a refund from them for the VB. My suggestion if you are about to spend $$ on a new tranny like I was about to two weeks ago - get a built one and not the stock.
Built is definitely the plan. Unfortunately it looks like that's not much more than a better converter and a few more clutches. Still baffled these trans have steel riding on aluminum, hell that causes problems in dirt bikes let alone a diesel pickup.
GM really F&**** this up.
