NEXTGEN Drivetrain valve body swap
What kind of issues did you have if I can ask? Was it the complete rebuilt VB or did you install their kit parts in your stock VB? Everytime I’ve called for tech assist and questions I’ve dealt with Tyler and he seems to be very knowledgeable. I was still having some hard downshift shift issues 5-4-3 downshift over 35 mph after the active relearn and my complete VB install. I had the fluid level verified and just did a Service Fast Learn TCM flash and about 500 miles into the Fast Learn and smoothing out on that 5-4-3 downshift now. Following this thread.
I originally installed their rebuild kit in my stock VB. Had issues with the "D" solenoid valve moving smoothly. Per their instructions I moved the valve manually until it seemed to move ok. Installed in truck. Had very hard and slow shifts but tried to drive for the learning process. After about 10 miles the truck downshifted hard getting off the highway and went into limp mode. Code was for solenoid D being stuck on. Cleared code and restarted truck, shifts were still very hard and then went back into mode, again solenoid D stuck on. After talking with Tyler I decided to go with their complete VB instead of fighting what could be a bad factory VB.
After receiving the new VB (which was completely clean and dry even though they claim its tested?) I swapped it. Truck acted the exact same way, except at that point almost every time it went into limp mode it was for a different solenoid. I changed fluid and filter the following day with the same result. Each time I read the codes I had one for almost every solenoid.
Mind you through all of this I was lucky to talk to NG once a day. I submitted all my info for warranty after finally talking with Logan. He said if I could get it shipped that day (6-23) they could get it back to me Friday (today, 6-26). According to UPS they received it yesterday morning and I have yet to get a response from either a call or email. I have sent them a message as well as left a voicemail.
I also spoke with Logan on 6-22. Shipped mine out the same day and it delivered on Wednesday morning. Yesterday afternoon I got a shipped notification and I just received it. I plan to install this tomorrow..hoping no more problems.
Did you also experience 4-5 second engaged delays when shifting from P to R and D?
Yes, every gear was 3-5 seconds. LUCKILY the shop I am using is not in a busy place as the truck couldn't get out of a snails way. Best of luck with your new VB, I'm going to try to get ahold of Tyler again to see what my status is.
I found that calling them back to back over a period of 15 mins someone eventually picks up the phone.
Yeah I also got a violent jolt each time it changed gears and when I tried to go on a test drive it hit 2k rpm and a violent jolt. I came right back. I don't believe it's supposed to shift from P to R and D so violently. And I don't want to grenade that tranny
I received mine back in early December 2025 and had the NG VB installed by a transmission shop I use. There was a paper in the box that said DO NOT FLASH TCM (or something like that) let VB adaptive relearn new shift points. So I did that. A little rough at first but noticed each day it got better. I have about 8,000 miles on my NG VB with a couple to long haul toe runs with my Airstream. I took to a diesel custom guy here as Tyler asked me to ensure fluid level was correct. So had the transmission level verified and asked them to flash TCM with fast learn set up. I was only having trouble with the 5-4-3 downshift above 35 mph. Since the fast learn it’s definitely better on the 5-4-3 downshift. So far, rough out of the gate but finally working in….8,000 miles later though!
Can you clarify what "a little rough at first" means? Was there a violent jolt? Any check engine lights?
So there was some “violent jolts” on the way home from the install. I was told to expect some “hard shifts” up and down the 10 speeds. After a day or two those hard shifts got much better. Keep in mind I followed the directions in the box the VB came in that said NO TCM Relearn just the adaptive learn. I did not get any CEL or any codes. Still have not received any CEL or codes in my Banks IDash Pro. As I progressed thru the 500-1000 mile adaptive relearn initially some of the now I will call them “firm shifts” were still pretty constant in the 8-9-10 up shift and the 5-4-3 downshift. I was working with Tyler at NG and he told me to get fluid level verified and continue the adaptive relearn since I wasn’t getting any codes or transmission temps normal or even lower than what I knew as normal. So the firm upshifts resolved on their own and now the issue was just the 5-4-3 downshift. I was having a Ready Lift Level Kit installed at local diesel custom shop and I told him my 5-4-3 downshift concern and he said I should do a “Service Fast Relearn” on the TCM. He verified my tranny fluid level and said I was 1/2 quart low and he initiated the Service Fast Relearn. So far my 5-4-3 downshift has gotten much better and this now seems to be resolving itself after about 500 miles on this Service Fast Relearn. During this whole 8,000 miles on my NG VB to date I’ve never received a single CEL or code throw. Hope that added some clarity.
Thank you for that clarification.
I believe the reason you were 1/2 qt low is probably because the transmission shop you used followed GM fill procedure which is power brake to 170. As you know, transmission fluid expands and the hotter it is the higher the level will be. Where as next gen says to drive it until you reach operating temps, then come back and check the fluid level again. I believe in your case, as my case, operating temp is going to sit at 140 roughly.
This one's on GM with the stupidest design. It made replacing the up pipes easier but that's the only plus about not having a damn dipstick.
My plan to get this done today rained out.
Update: the transmission God hooked me up. The rain stayed away. Everything works! Zero issues. No harsh shifts up or down.
For anyone reading this in the future - follow the following fill procedure:
1. If you are installing a banks (like me) pan - you will need roughly 23 quarts. I bought 25 just in case.
2. Buy a power fill tool - I got the motive power fill. The tool kept coming apart so keep a ,13mm wrench handy so you can fix it as you keep pumping the handle
3. Since no one online or on YouTube can clarify:
Pump the fluid in until it starts to come out of the stand pipe
4.once fluid comes out - turn the truck on. The fluid will immediately stop coming out.
5. Continue pumping fluid in (roughly another 8-9 quarts) until you see fluid come out steadily again WHILE RUNNING
**DO NOT TURN THE VEHICLE OFF AT ANY POINT**
6. Once fluid starts coming out again - go back in the truck and shift down the gears pause for at least 3 seconds in each gear (P-R-N-D and back up).
7. Verify that fluid still comes out the standpipe - if not, keep adding
8. Close everything up and go on a drive until you hit 140 degrees roughly. I went on a drive and stopped off the exit to power brake myself to 140.
9. Come back and park. **Leave truck running*** - take the standpipe bolt out - you will probably have a gush of fluid come out. Let it drain a bit until it slows down. Close up and you're done.
That's great to hear, man I hope my next vb goes well. Never got a return communication from ng so still in the dark since Tuesday.
As for the other post, my CEL came on almost immediately, with a laundry list of issues. Seems ng quality is going downhill recently and unfortunately I'm on that slope.
I think you and I just "lucked out" with who assembled our first VB. It was the same with my CEL - 4-5 second shift delays from P to R/D and then the harsh jolt around the corner when the CEL went on.
When you get yours back - before you turn it on - plug in a fancy scanner and clear all codes. Mine cleared right away.
I also never got a confirmation. Just that UPS delivered. Some 30 hours later I got a notification that the replacement shipped. Hope your next VB works out and you can have your truck back. I can now sleep at night.
100 mile update:
Small jolt when switching to D but nothing big and should work itself out.
No harsh down shifts or up shifts - just a small I don't even know that I want to call it a jolt - more like a felt gear change during cruise control trying to hit 65 from 60 during a downshift from 10 to 9.
Transmission temp is at 120 degrees (down from 144), did go up to 134 in stop and go traffic.
Nextgen recommends as a "last act of good faith" for you to check the level again at 100 miles. Mine was just a tiny bit low and also possibly low because my fluid temp check yesterday was at 140 with the fluid expanded more, this one was at 132 when I came back from the 100 mile road trip
Well my bad luck continues. Got the new VB in this afternoon and at first everything was much better. However when the truck tried to shift around 35mph it went back into limp mode. Solenoid A stuck open. Talked to the techs at NG and they think it could possibly be a stuck clutch so now the truck will have to be towed to shop so they can run diagnostics.
This is def in the top 3 biggest regrets of my life. Just trying to do preventative maintenance and now I'm 5k in the hole with the kit and multiple fluid changes and now having to find/rent a truck to move equipment just stacking on top of that cost.
Have you tried to do a reset/relearn with a scan tool?
