gm has released the 2/3500hd upfitter switches...
The switches were installed from the factory. The bag of parts/cables we in the back seat for me to deal with
Guy's, I just did some research and here is what I found for my 2025 but they also have info on other years... Go to GMupfitter.com Bulletin 205... That explains in detail how to add the up fitter harness for the Installed switches. Hope that helps everyone! The trucks produced late 24' that are 2025's have the switches installed from factory in console but no Fuse block is installed only supplied if you ordered the Upfitter switches from factory. That's what I was able to find it also explains the dealer doesn't install unless purchaser told them too at the purchasers expense. Crazy buts that what was explained... Have a great day!!! JC
It does look real but I have not found a thing anywhere else about it. Saw it on Facebook.
As far as the shifter, all GM had to do was put D just a couple of degrees farther down in the shift pattern. In my case if I shift to L the shifter blocks nothing.
It's at 404parts.com
I did the factory upfitter switches too. Expensive but seems to be a good option. Only problem is they are all full now. I guess I can try the Garmin option for additional accessories.
What all do you have installed? We want PICTURES!
Lol!
1. 3 BD spot/driving
2. 2 BD flood/fog
3. All 5 backlight
4. All 5 low beam
5. Rear bumper BD quads
I want to rig some “blinky” or amber flashing lights. I’ll need to switch those. Maybe some ditch lights and side/rock lights.
I popped the hood on a truck with up fitter switches at the dealership and nothing there to hook up to. Dashboard has to be torn apart and a separate harness (not included) needs to be purchased and hooked up on the customers dime or labor. Just blows me away. Ford is as simple as it gets with marked pigtails ready to tie into under the hood.
Still I would not get a Ford......
