DRL Recall
Thanks!
I just looked, and I don't have that button. The AT4X has the rear locker button, then next to that the full locker button.
On a different note, I actually don't like the "tailgate down" button. It sits right next to the button disabling traction control. I usually disable traction control once I get close to my house and steep/winding/narrow qtr mile driveway that has feet of snow on it in the winter for at least 6 months here in Montana. It helps to disable traction control in those situations. But sometimes I accidentally hit the tailgate down button instead of traction control. It has yet to cause me a problem, but as a contractor I have misc tools/etc in the back of my truck often, and having the tailgate down without knowing it I could easily lose some stuff out of my bed this way.
I did buy the GM bed mesh/web thing that you can attach to the tiedowns to string it across the bed, got it for $68 as it was on discount, but still pricey for what it is. Just put that in yesterday, so that should mitigate some of the risk of losing stuff out of the bed. I have a BAK X4S on the way, supposed to be delivered tomorrow. That will keep snow/misc out of my bed, but the tailgate can still be accidentally dropped with that button on the console. Wish there was a way to disable that button or reassign it. If I am pulling my job trailer, if the tailgate gets dropped, it will likely end up hitting my trailer crank, denting the tailgate. Will be pissed if that happens. Happened several times on my 2020 AT4 as it had that same button to drop the tailgate, but that button was in a different/harder to hit spot on that truck. Still happened a few times. Disabling that button would be ideal.
Yep, I have accidentally dropped the tailgate a couple of times already. I'm going to be beyond mad when my trailer is hooked up and my tailgate gets smashed.
Yep, dropping the tailgate if I have my job trailer hooked up will guarantee at the very least the top of the tailgate will hit my crank on my trailer. If I go make a tight turn... it would probably be a lot worse than a ding/dent in top of the tailgate.
