Coolant heater
Are you asking about a 6.6 diesel or gasser? The diesel should already have an oem block heater.
If you are asking about the gasser, I'd be really hard pressed NOT to install the gm oem parts.
I have block heater but when I haven electricity to plug the block heater. I am asking for that option aboit WEBASTO cooling heater.
Installing one will lead to repeated code P111E Coolant Temp Not Plausible. The ECM compares various temp sensors at cold start and if one is different than the others (your coolant temp would be higher than the others) it throws the code.
If you call Webasto Tech they will not recommend installing. There is no work around.....yet.
Also, if you try to install one DON'T tie into the factory fuel lines, they are under 60 to 90 psi of pressure and will immediately flood the heater with uncontrolled fuel.
If I can't plugging my truck at night, Could I to connect the truck to ECOFLOW PRO 3(3KW) during 2 hours before to start my truck? Or Are there other solutions?
