Constant alignment and tire wear issues.
On past trucks I always felt the duratracs from factory on a new vehicle must be a softer compound .....mine never lasted, when is put the same tire on for 2nd set on the trucks they would last at least twice as long ....
I eventually tried BFG KO2 and loved them! So was happy to be able to order the latest trucks with the KO3 tires
Just as an FYI, the tires that come on a factory vehicle ARE a special order compound made to vehicle OEM specs for that vehicle.
This means a OEM BFG KO2 is not the same tire as the BFG KO2 you get from your local tire shop.
Vehicle manufacturers do this to meet their vehicle MPG statements and NHTSA requirements.
that confirms what i always felt may be the case from my tire wear experience
They don't report mileage per gallon on diesel heavy dutiys , at least to my knowledge they don't, I've never seen it
Hey all,
2021 AT4 owner. Smokey quartz, with all the candy. Owned Yukon's for years to tow my boats. When kids entered middle school, boat never got wet, sold it, and moved onto a more comfortable family car and drove Buick Enclave's. Kids are up and out, want to get back to towing but wanted a general purpose vehicle that was as comfortable off-road as on. Thought the AT4 would fill the bill. 16,000 miles later and I am needing a new set of tires. My vehicle has been in for alignments about every 3 - 4k miles. And all the dealer can tell me is that it does not take much to knock the car out of alignment. The worse this truck has seen is gravel. Looking for some feedback on anyone else experiencing this kind of issue.
Thanks in advance for any direction you can offer.
We have the same issue bought brand new 3 months later needed new tires. They replaced them did it again so we thought they were the tires they were putting on it. so we went to the tires store every 8 months I have to put new tires on it and get realignment done every 3 months I think it's time to trade it in. Did you ever solve the problem?
Update. Spoke with regional service manager. They are replacing my tires free of charge. Says it’s not an alignment issue, it’s a crummy tires issue. Goodyear Wranglers, the ones GMC put on my 86,0000 truck, are crummy tires I am now told. Great.
please tell me that worked i put so many good tires on mine still issues
I am having the same issue with my 2025 at4 1500. they told me the same thing about the crappy tires. replaced with K03 tires and they are doing the same thing. I get a Whooshing noise at around 35-40 MPH. dealer says this is normal for this truck. first set of tires lasted 20K. My K03's are wearing out at about 16K on them. Been aligned more than all the vehicles i have owned combined.
So many are driving with under inflated tires due to reading the recommended inflation on the truck instead of the tire. What the vehicle shows is the minimum safe inflation, not the proper inflation. My truck shows recommended 32-36 but Goodyears should be around 45. KO3’s should be inflated to around 50-55 (unless driving off-road). Under inflated causes excessive wear on the outer edges
I had an alignment done after the upgrade in shocks/struts/UCAs and it last less than 4 weeks before the front tires were worn on the inside. I have the alignment sheet before and after and they had it dialed in. Needed to replace the tires while in a road trip. Had an alignment done and it was way off, to the point the shop questioned if one was even done originally. 18 months later same issue with a a bad alignment and tires worn on the insides. I rotate every 5-7K miles so all four are wearing on the insides. I do have 30K miles on the new tires so if I have to replace them early I did get some good use out of them.
This is definitely not correct information.
The pressure listed on the tire sidewall is the maximum inflation pressure for that tire, which it should be set to if you’re carrying that tire’s maximum load. The pressure listed on the vehicle sticker is the pressure for the maximum weight the vehicle is rated to carry. There is no reason to ever inflate higher than that on stock tires, and you most likely should be running lower pressures. Running higher pressure will absolutely wear your tires out faster, as well as decrease your traction and make for a worse ride.
Run your truck across a scale and set pressures using the “load inflation table” for your tire, as published by the tire manufacturer.
I had the same issue on my 2023 and it all went away when the factory tires were swapped out.
