Constant alignment and tire wear issues.
Dr Pro
Georgia
Hey all,
2021 AT4 owner. Smokey quartz, with all the candy. Owned Yukon's for years to tow my boats. When kids entered middle school, boat never got wet, sold it, and moved onto a more comfortable family car and drove Buick Enclave's. Kids are up and out, want to get back to towing but wanted a general purpose vehicle that was as comfortable off-road as on. Thought the AT4 would fill the bill. 16,000 miles later and I am needing a new set of tires. My vehicle has been in for alignments about every 3 - 4k miles. And all the dealer can tell me is that it does not take much to knock the car out of alignment. The worse this truck has seen is gravel. Looking for some feedback on anyone else experiencing this kind of issue.
Thanks in advance for any direction you can offer.
is the tire wear on the inside or outside of the tires, and is it just the fronts or all of them. Also is the steering wheel straight when driving straight on the road? Do you have any aftermarket parts lift or wheels.
The reason I am asking is premature tire wear at low mileage usually is not due to alignment issues, unless you way out of whack. My old 2017 went 97,000 miles on two sets of tires and never had an alignment. I live in NH and travel to the pot hole state of the country (Massachusetts )frequently.
Outside. I have had the car in every 3 - 4 k miles, and the fronts have needed realignment every time. Wheel straight, no pulling, tracks straight. All tires are now ruined due to the constant rotation. Interesting to note that the fronts have been out the same amount each time. Car is stock. The dealership keeps saying I must be hitting something when I drive. It’s an AT4. If highway driving is enough to constantly knock the tires out of alignment, I can’t imagine what the repercussions would be of taking it off the road. In the dozens of cars I have owned in my lifetime, I have never had a car needing alignment. Appreciate your input.
I get why they keep on saying alignment because outer edge is 8 times out of 10 the issue. However, alignments don’t go out of wack multiple times so close together.
Like I previously stated the only time you need an alignment is not tracking straight, pulling to one side, or steering wheel not straight. I also understand the Goodyear wranglers wear fast but not that fast.
It’s time to speak to the general manager, have them look for bad ball joints bent tie tie rods, defective shocks, or even bent strut assemblies. Especially since you’ve had the rims and tires looked at. In my 55 years on this earth I have only had a front end alignment four times, and one was so bad I snapped a forged rim in two.
Update. Spoke with regional service manager. They are replacing my tires free of charge. Says it’s not an alignment issue, it’s a crummy tires issue. Goodyear Wranglers, the ones GMC put on my 86,0000 truck, are crummy tires I am now told. Great.
Yeah I have heard GoodYear duratracks are a hit or miss, I currently have them on my 2023 1500 AT4, and they were on my 2017 1500 All terrain. I never had an issue with my 2017, but I don’t know about my 2023 since I only have 1000miles on it.
Significant Early Tire Wear -> We have Goodyear Trailrunner A/T 275/60/R20 on our 2023 AT4 Yukon. Tires are a 1 out of 10 on the front right and left, they are a 3/10 in the rear, according to GMC Dealership. Tires have been rotated twice now. We had the front /rear differential changed 3 weeks ago. Vehicle has 34k miles, recently we noticed a stuttering feeling in the steering wheel while turning at low speeds. Car is driven locally by my wife. Never been off-road. Never towed anything. My thinking is this truck has an issue, not the tires, but could be both. I noticed at 18k miles there was already significant wear. Hence a quick, early rotation. They want us to replace the tires before they address the stuttering problem. $1250 for 4 of the same tires. They of course want an alignment too, fair enough, but the car drives dead straight, zero pull right or left. Tire wear is on the inside and outside. I think GMC has an issue. I'd like to hear from anyone else who is having early, premature tire wear way above normal? Most of my cars in the past get 50-60k miles (Rubicon, 4Runner, Sequoia, Landcruiser) without fail.
Looks like the front end toe could be out of alignment. That will cause wear on the outer or inner edges. Toe-in will cause wear on the outer edge and toe-out will cause wear on the inner edge.
Camber out of alignment can also cause similar wear patterns, but is usually much more pronounced.
However, since you said the wear is on both the outer and inner edges, it could also be underinflation.
Thank you very much. Trying to get the tire warranty on the tires as Goodyear says they are warrantied to 55k, so far GYear has been very helpful. I'll update you all post everything being completed. For the moment, just waiting on GY.
Good Year gave us $400 towards new tires. GMC never stepped in to help or advise. One other person also suggested the camber, however, Sullivan's Tire (big in Mass.) found the mildest alignment issue, but said it was so minute that it would not really warrant a mention other than me pestering them for any clues on what's causing this. We are 8k miles in on the new tires, highway miles to Vermont, and not looking great.
I own a 2020 AT4 with the 6.2 and 20" rims. Had BFG KO2 tires since purchase in March of 2020. Closely monitored air pressure and had tires rotated every 5K miles. Now have 39K miles on vehicle and all tires are badly cupped. Obviously some vehicle issue. Just had front end checked and lined. I guess my next step is to replace tires and hopefully not have this issue again. Unless someone has any other suggestions.....I'm all ears!
On past trucks I always felt the duratracs from factory on a new vehicle must be a softer compound .....mine never lasted, when is put the same tire on for 2nd set on the trucks they would last at least twice as long ....
I eventually tried BFG KO2 and loved them! So was happy to be able to order the latest trucks with the KO3 tires
