AT4X leveling kit
View attachment 1934View attachment 1933View attachment 1932Hers is mine. I ”flipped” rear blocks, yes it lowered it a little in the rear but now I have a level truck. Got rid of chrome lugs. Put on Toyo MT’s 285/70/18. No cutting, no rubbing and full wheel wells. Still have factory smooth ride!
I know this is old but did you have any problems with your factory rear shocks? Since they are longer and made for the 2” block. I thinking of doing this same thing on my 2021 AT4 and wondering if I should get shorter shocks since I’m buying some new ones anyways. Thank you
Never had any problems at all. However, reading post here shorter rear shocks may have been a better ride. Overall, happy with setup for me
Well, I went with a 1 inch block, that only resulted in more work! LOL. Still nose low. The picks are no block at all. Hope this helps.
I realize this was a long time ago, but how did the 285/75R18s work out for you? I am close to pulling the trigger on a 2" Peak Suspension leveling kit with BDS UCAs. The only thing holding me back is if the 285/75s will fit with little to no trimming.
Well the tire/wheel combo barely fit!
Plan to do very minor trimming to be safe and considering removing the front mud flaps as that would likely solve it.
Discount Tire installed The following:
285/60r20 Nitto Ridge Grapplers (33.7”x11.5”)
Fuel Rebel 6 (black) 20x9 and +1 offset
Thanks and hope this helps anyone selecting their set up, and very happy with the new stance and overall look. Should have come from factory with 33-34”s IMO
Great set-up!
Installed the 2” spacer and Zone UCA
Achieved 1.75” of lift and truck went from a 2.25” factory rake to only 1/2”, which looks perfect IMO
Original plan was a 295/65 (35.1x11.8) on 20x9 +20 wheels, but the new UCA are very beefy and the extra thickness barely rubbed at full lock.
I have to go to a +1 wheel offset and sized down to a 295/60 (33.9x11.8) so they would clear.
Overall I think it came out great and now working on chrome delete badges, etc…thanks
This looks great!
