AT4X AEV bumper with hooks
Your front hook width measurement shows 1.25" (see your pic above) whilst mine is 1.33" on my AEV, strange but true; specs on Amazon show the shackle mouth gap should be 1-1/3" however reviews state the gap is 1-1/4". I'm trying to locate a 3/4" shackle with a 1-1/3" mouth gap. Although I have a set of four 7/8" 6 ton shackles with 1" pins which are great for the rear however they don't fit the front due to my fog lamp mount protuding out, hence planning to order a smaller set for the front for emergency use although I have a set of soft shackles which should be more than adequate for emergency use up front.
Once you start using soft shackles, you'll retire the clevis's to your box of chains and cables.
Just grab yourself one of these and call it a day. Should be able to pull 15 trucks at the same time.
  • Like
Reactions: amf
FYI check out these shackles: you never take them off, the pin is set and done. They are slick. If I was buying new shackles, I would consider those. Although soft is the safest way to go.
Let me google: HERE
They're from Moose Knuckle
It was annoying I couldn't use those in my 2500HD AT4X AEV, since I have a lights installed in openings next to the to hooks; still have a set of 6T shackles I can use on the rear and soft shackles for front or rear use; I was compelled to listen to other experienced members :)
  • Like
Reactions: amf
Good to know.
Found these, pricey but they fit perfect.
Searched the forums and AI for shackles for a 2025 Sierra AT4X. Found a cheap set that fit, (although still think I want the Mooseknuckle JOWL (just can't pay that much for them at the moment)) and really like the way the company operates.
Favorable call out for GearAmerica. Will certainly keep buying from you. Bought on Amazon, and happy to support.
Pic's to follow.
Got mine from moose knuckle. Real happy with em because the size, and the split so they open up easily. Also they’re sort of locked on there and can’t be taken off without a special tool.
@mocomajek - those are the ones I want. Maybe a black Friday sale will help. Those are great both because of fitment and how they operate.
