AT4 2500 Factory Denali Swap?
They are going to Crank the Torsion Bars down till the Fender is at 40.5inches. Hoping the 1.5”inch drop will help with how Bad it’s been riding. Plus the Bad Idler & Pitman Arms. I noticed my Steering wheel had some play in it but wasn’t sure exactly what could be causing it. It’s getting worked on right now so I will Update this afternoon.
Idler and pitman absolutely will cause play. Hopefully your shocks weren't overextended but I suspect with that much torsion bar lift and if the guy didn't install spacers or extended shocks they probably were. If you ever replace shocks and you're at or near factory heights I wholeheartedly recommend the Bilstein 4600's (yellow and blue ones). I have these shocks on mine and I think they're the best riding shock for pavement queens (like mine). 5100's are valved slightly more aggressive.
I just got Fox 2.0 Shocks all around. The Shop called me and said the Truck is Ready to go. After work I’ll see how much of a difference the truck Rides. The Factory Ranchos weren’t Blown Out so the Fox Shocks should help out a lot.
Just picked up the truck and it Rides so much better. Glad to finally have the Steering/Suspension Issues Fixed. Night and Day difference. Still looks good with the Front being lowered to Stock Height
I was told the 4600 wouldn’t work with the At4 only standard non lifted trucks?? Does yours work ok?
That is incorrect, they work perfect with my stock AT4. What you are probably referring to is the AT4X (factory installed 1.5 in suspension lift).
That's awesome to hear. Glad it worked out for you.
