275/65/20 Tires? LT or Standard Load?
I like them a lot so far. They are much quieter and softer than the Goodyear mud terrains that came stock. I haven’t had them in any snow or ice yet, so I can’t speak to that yet.
They look great! I'm thinking of getting 4Play 4P06 wheels to go with them. I heard the Falken's are quite a bit heavier. Have you noticed much of a difference in your MPG?
The max PSI on the sidewall is to be used when you are carrying the max load rating of the tire. Most of the time the tires load rating will exceed the GVWR of vehicle they are mounted on.
This member has put it in plain simple to understand terminology:
For those who say it has to be aired to tire sidewall PSI: WRONG. I have had a couple of Jeeps that came from manufacturer with LT tires and the PSI in door sill was well below the MAX.
