275/65/20 Tires? LT or Standard Load?
24ThunderGray
NC
I am looking into this size as it's getting close to me needing new tires. I have read that this size fits stock suspension with factory mudguards and NO rubbing? I hope that is true. I really don't want any rubbing. My questions are for those who already have tried this size. Do they actually fit without rubbing? Did you choose Standard load or LT? If you chose LT, did it mess with your TPMS computer in the truck when you inflated them to above 60lbs? My truck and wheels are stock, and I don't plan to change wheels or add level kits or any of that. My truck already sits level as I reverse leveled mine a long time ago.
This is the same size tire I am looking at getting in a BFG KO3. From what I have found the tire is about 0.5” wider and is just over 1.5” larger in diameter. I am pretty sure you should be running LT tires.
not the same tire or size but I’ve got 295/70r18 tires on my AT4X. About 50k on them. SL rated and no issues. In addition to a lot of highway miles I drive a lot on crappy back roads, gravel, logging roads etc. no issues. And they are a lot lighter than LT rated tires which, in my opinion, are overkill on half ton trucks
@RedragonX - I just put a set of KO3s on my '25 std bed - LT275/60/20 in load range D and have zero issues. i tow a small RV around so was interested in the larger load range for towing. was always a bit nervous with the bridgestone duelers on some of the fire roads i take in the idaho mountains. had the KO2s on my previous truck and they were monsters in the snow. couldn't pass up the b3g1 GM ran last month. hoping the KO3s perform just as well.
@24ThunderGray why would you be inflating to 60psi? [not criticizing, just curious]
I’m running 275/65R20 Toyo Open Country RTs in the standard load. That is the load that came on the truck factory, which met the towing capacity standards for the truck. If I was a hard off-roader, rock crawler, etc., the higher load range tires would make sense for me, but not for regular towing within the factory specs.
As to fit, I did the RC 1.75” leveling kit with new UCAs and the RC mud flap delete at the same time as tire install so I can’t say if they rubbed at factory height. I will say the tires are now a little closer to the upper ball joint with the RC UCAs than I’m really comfortable with so I’m between spacers and different wheels.
Because the LT tires can run a higher air pressure than Standard load. Not sure I would run 60psi, but I know some tires can go up to 80psi.
From everything I have read, they are the same width (275) and only 1" larger in diameter. If anything the actual width should be less because it's a 65 series profile instead of a 60 series.
Where did you find them? The only Toyo I can find is the AT3 but they show they are for electric vehicles?
I bought mine through my dealer who sourced them from a local shop but it seems like most of the big tire stores sell them. The standard load for these tires is the “116T” rating.
This is a link to the tires I am running. They are 34.1” x 11” and weigh about 48#s.
https://simpletire.com/paid?brand=t...Ky8Pho66sYs1_Qzsf0YyERFFDKzamX7AaAlKsEALw_wcB
I am running 275/65R20 and didn't have any rub before I leveled. Odd, but I think the control arms rotated the front tires back. By that I mean, I believe the arms gave it more caster by rotating upper balljoint back a few degrees. As of now, I've hacked my mudflaps and liners so meh, not worried anymore.
No way a 1500 needs 60 PSI. The sidewall limit is just that the LIMIT of how much pressure you put in it. You should still inflate to door sill PSI or slightly lower due to stiffer sidewall sidewall in the LT.
No way a 1500 needs an LT tire either but there are cases where you have a certain tire in your size you desire but the tire manufacturer only makes it in the LT tire. I have LT tires on my Jeep for this reason but no need to inflate to MAX pressure stamped on the sidewall.
For those who say it has to be aired to tire sidewall PSI: WRONG. I have had a couple of Jeeps that came from manufacturer with LT tires and the PSI in door sill was well below the MAX.
I just installed Falken Wildpeak A/T4W LT275/65R20. All my suspension is stock and I have no rubbing at all. I am running them at 38-40 psi. In my opinion, there should be no reason you would ever run them at 60 psi.
Thanks guys! I truly appreciate the help. It wont be long before I need new tires and definitely going with this size over the stock ones. I know it's not much difference but it's enough for me.
I'm looking at getting this tire as well. How do you like it? Would you be able to post some pictures?
Thanks
