2023 1500 AT4 Makes a small thud just after stopping.
The dealer said it is the fuel and in a normal. I call BS never had anything else do it.
I have the same noise coming from mine, sometimes it loud sometimes it’s not bad. Doesn’t seem normal. Has anyone found the fix? I have also had a ton of problems with the heat shield rattling and getting the exhaust right off the engine.
It is fuel in the tank. Does it on mine when full, till itS just under 1/4 of the tank. It is louder the faster you stop. Gm told me was a bulletin on it and it was a normal. BS
Hopefully enough people complain and make reports. Something is wrong with the baffles in the tanks.
I thought there was baffles in the tank to stop the fuel from sloshing around. I had the same problem a long time ago on a Chevy (gas) pickup. Every time I came to a stop there was a thud and the dealer said it was the drive shaft, so they changed the drive shaft from a steel shaft to a fiberglass shaft and that didn't help at all. Eventually I just got rid of the truck and bought a cummins' and ended up with all kinds of problems. So, then I bought a powerstroke that I loved. I had that truck for 10 years before I rolled it. So, I moved on to GM only because I could get the employees discount (my BIL). So they just say there is a bulletin on the problem but don't offer a fix. What bullshit!
Just started hearing this thud yesterday on my 2022 refreshed 3.0l standard bed. Super annoying to hear. I will bring this up at my next service appointment.
Did you have this addressed?
Mine is starting to make a pop or knock, coming to a stop or just fully stopped. 15mph and under it seems like. I can't pin point where it's coming from. Sounds like the rear sometimes and others sounds like the front. Doesn't always happen but is happening more frequently.
It went away before the service appointment. I had they check it out, but they didn't see anything loose. The sound hasn't been back, so I haven't done anymore digging into it.
