2022 AT4X - Larger Tires/Wheels Installed - Pics and Review
Those def look awesome and hope they work out for you. Keep in mind the stock wheels have the offset that will give you the best chance for a taller tire. I have a 20x9 +1 Fuel Wheel which def makes a difference and limits my size some to achieve the stance desired. Thanks and good luck!
Thanks! Yup, trying the 285/65's with stock suspension and stock carbon pro 20's. We'll see...
Put the 285/65/20 Mickey Thompson Baja Boss's on today. There was a small amount of rubbing on the mud flap at full lock and when turning up a slight incline. So, I trimmed the front a bit and removed the mud flap bracket. Now, no rubbing at all.
You did the rough country UCAs ? Do you need them with the At4x suspension already gm doesn’t use high angle arms with the factory lift ?
Yes - I did. My understanding was highly recommended as stock angle could causes issues
Added the 1.75” Ready Lift kit today
Huge improvement and now zero rub
First post here...trying to figure out what I'm going to do to my 23 AT4 if/when it ever shows up... Anything you think I need to be aware of if I do the exact same setup with a different +18 offset wheel? I'm assuming it will help a little with rubbing at max steering angles but wasn't sure if I'd be getting to close to the knuckle/ball joint. If you've got a picture of clearance from inside of tire to the ball joint on your setup that would be awesome to put my mind at ease, otherwise if you know it will fit (which I think it should) then that's great just to hear. Do you think with the level and a +18 I'll still need to do the mudflap delete and any trimming? (just normal AT4 not X).
Nevermind...I see the above post now about 285/65R20's on stock wheels. Should have read the whole thread... +18s should be fine.
Rough County AT4X 1.5in Level w/UCA and Nitto Recon 285/75r18
Do you have any rubbing or and issues ? did you have to trim anything ? your truck looks great with those tires i would like to do the same
Hi, yes that will def work well and clear no problem with a +18 wheel. Look forward to seeing pics when you get your ride!
Have you added the flap delete kit yet? If so, do you happen to have any updated photos with that kit, as well? Any issues?
I'm basically recreating your truck in NC... :D
Yes, please see pics here after delete kit and trim kit. Came out very clean looking and appears to be like OEM in my opinion. Best of luck with your build!
Looks good, what fender delete/trim kit did you use?
Here is a link to the kit
Hey! Had questions/need confidence in potentially purchasing AT4X. Can you text me? 256-698-4901
