Method 315 Polished w/Black Lip 17x8.5 zero offset with 35x12.5 Nitto Ridge Grapplers. front driver.webpfront passenger.webplevel 3.webpMethod 315 polished with Nitto 35.webprear driver.webp
FUEL WHEELS VARIANT D791 - 20 X9 6-139.70 1 BKMTXX
TOYO TIRE - OPEN COUNTRY A/T III - LT275 /60 R20 123T E1 BSW
Fit current GM 1500 trucks. Only a few thousand miles on the tires. Like new.
Black lug nuts and tps sensors included.
Retrax PRO XR Manual Retractable Tonneau Cover w/ T-Slot Rails
Part #: RTX-T-80481
For Current GM 1500 trucks. Just a few thousand miles old. Like new.
DM offer.
These are still for sale. DM offer.
Alrighty I'll play.
2025 AT4 1500 with 1.5" leveling kit and RAS out back.
Wheels are Method 803's 20x9 with 0 offset
Tires are 295/65R20 Toyo RT Trail
Rubbing - YES EVERYWHERE lol
I've already trimmed what I can and I've minimized most of the rub. Articulation = not sure right now, but future I plan on going with a 2.5" BDS lift for a little bit more clearance and better angles.
Alrighty I'll play.
Yup I notice your not running your mudflaps. I am in the same boat. I'm running the RC Mudflap Delete Kit and it definitely helped. I am also wanting to go up another inch or so, so I am also looking into adding the BDS 2.5 for a tad more height and way better angles.
Yeah I had to remove them the day I put the tires on. I was able to get the driver side on after I trimmed it down about 80 percent. Haha. I’m pretty fine as it does what it should. I want to do the 2.5” from BDS but looking for someone with it on to see what their actual height is from center wheel to fender. I feel like we are probably there already but they just have better CV angles. I wish that kit didn’t come with shocks, I definitely would have bought it. I just don’t want fox. Would like to go king or keep my 6112’s or Eibach coils lol
4Play 4P06 wheels in 20×9 with 0 offset.
Falken Wildpeak AT4W in 275/60/20
Stock suspension no lift or level. Slight rub in reverse at full lock in both directions.
Alrighty I'll play.
Nice!! Please keep us posted on the BDS, I am also thinking of going that route.
I was able to fix 99% of the rub by removing the bracket behind the factory mud flap. I followed this video.
Yes that bracket has to go! I went with the RC mudflap delete kit and it works pretty good and makes for a factory finish. There was a little cutting but nothing major...
Yes that bracket has to go! I went with the RC mudflap delete kit and it works pretty good and makes for a factory finish. There was a little cutting but nothing major... View attachment 35342View attachment 35343View attachment 35344
Yes that bracket has to go! I went with the RC mudflap delete kit and it works pretty good and makes for a factory finish. There was a little cutting but nothing major... View attachment 35342View attachment 35343View attachment 35344View attachment 35345View attachment 35346
Great pictures! Honestly that little bit of cutting is what scared me away from the RC kit. That and I actually don't mind the look of the factory mud guards.
It looks like the only tab you lose is the bottom one correct? So you could put everything back to stock if you wanted to you just wouldn't be able to use that bottom screw anymore?
thank you! . You are correct. The factory mud flaps can be put back on if needed. reinstall the bracket and mount it back in minus that one spot. Also noticed the fender liner a tad off there. Ill be looking at that today :ROFLMAO:
2026 Sierra 1500 AT4
Wheels: 4Play 4P06 22x10 -18mm
Tires: 35x12.5 Nitto Ridge Grapplers
Lift: 4" Ready Lift w/ Rough Country Mudflap delete kit
Trimming: Minor plastic - No rub :)
Looks and drives great!
