That's what we are here for. Glad you bought yourself a scanner, nowadays it's like the timing light of days gone by.
I only very recently threw my brand new timing light from decades ago. It was still in its original packing case.That's what we are here for. Glad you bought yourself a scanner, nowadays it's like the timing light of days gone by.
I run the xtool d8bt for all my scan needs. Will be upgrading soon however to probably an icon t8 or 10. Don't cheap out on these scanners is my advise to you - they're all very similar and it's a matter of preference.Good to hear you were able to resolve that issue. Do you mind if I ask what scanner you went with?
So what scanner did you end up ordering?Just to give a quick update, I had to buy a scanner to clear the DTC and now I have no issues. Front brake pads show 48% and the rears at 100% as they should be. Thanks to all that responded and gave advice, I appreciate you all.
Have you tried having the brake monitor system checked with a scan tool? Could be worth checking for any stored codes.Hi all- was wondering if anyone has any advice as I am having an issue with my 2022 AT4 not detecting new brake pads. Just replaced the rear pads only with a new pad sensor. I used all GM parts, no aftermarket. Followed the correct procedure of placing the vehicle in brake service mode. Confirmed that it came out of service mode when I was finished installing the pads. The vehicle won’t detect the new rear pads to allow me to reset the pad life. Dash still is saying I need to service the brake monitor. When I go to the pad life screen, Service System remains on in red and cannot select “rear pads installed”. Truck has 48,800 miles on it and the front pads are still at about 40% or so. Anyone else come across this with any advice? Any help would be greatly appreciated. Thanks for your time….
