Thanks! So there's nothing to be over concerned about? Currently hauling a 14k RV headed home.It is an o ring fit so don't overtighten it!
Dry it with a towel and monitor. If it's not leaking nothing of concern if a leak continues then you might have a problem with the housing or lines going to it.Thanks! So there's nothing to be over concerned about? Currently hauling a 14k RV headed home.
Thanks so much! Damn thing only has 17k miles!Dry it with a towel and monitor. If it's not leaking nothing of concern if a leak continues then you might have a problem with the housing or lines going to it.
Or it may only be the o ring got pinched but not very likely the way the housing is designed. Like he said, clean it up, monitor it for a bit with it running and send it!Thanks so much! Damn thing only has 17k miles!
