Trailer TPMS sensors
I used a handheld tire sync tool for my camper tires that I got when I bought wheels and tires for my truck. I hooked up the camper and went into the trailer settings to set the activation I believe. Then scanned each of the trailer tires. Seemed to work perfectly. Now every time I hook up the camper they sync immediately. Not sure if it matters or not, but I did create a trailer profile for it, and all the other trailers I pull. When I hook it up, it prompts for which trailer profile I want, and I select my travel trailer.
Thanks Jake. They are being installed this week, so I will see what I can find. I'm guessing that if it's in the instrument cluster settings, I'll find it.
Does truck send alert for low trailer tire like it does for regular truck tires?
I don't know if it does or not (thankfully no experience with that), I would assume so. When I set mine up it asked for a target psi for the tires, so I assume they build in some sort of threshold for alerts. When you go into the trailering menu with the sensors connected it does give you a big "OK" and a checkmark so you can tell at a glance that everything is as it should be. Then there are individual temperatures and pressures shown for each wheel in smaller font. Attached is a picture of what I'm talking about. Not my picture, I just googled it, but it looks exactly like what mine looks like.
Yep, completely understand. I was skeptical about the amazon ones, but the reviews seemed positive and others said they worked on trucks just like ours, so I took a chance. Love or hate amazon, but their return policy on things that don't work out should be implemented by everyone ha.
100% - I've bought them for 2 trailers off Amazon and have absolutely no issues. $30 for a set of 4 from Amazon vs. $150 for a pair from GMC.
I've never had them alert, but I keep that screen open when on the interstate and I don't remember what the threshold was, but the colors changed from green to yellow when the tires started heating up (105℉ outside temperature running across the high plains). - never went red, which I assumed should have generated an alarm.
Good to know. Mine have never been up that high, or changed colors yet, but good to know nonetheless.
