Seat covers
I understand this is an older post, but I’m curious about the gear you outfitted on your truck. Specifically the Baja Designs lites. You wrote “CarPlay and voice controlled” next to it. The lites are voice controlled? I don’t understand
I built my own wifi/bluetooth switching interface from ground up and it integrates with carplay and Alexa voice system. I can control lights from the carplay screen only after the truck starts and wifi hotspot becomes active OR from an app on my iphone using bluetooth.
I built one switching circuit for the front bumper fog lamps and another for the rear bumper fog lamps, with the rear housed in an ABS Plastic Dustproof/Waterproof Electrical Project Enclosure Box, bolted somewhere below the rear bumper.
Its complicated and not an easy build, however, I built it since at the time the only switcher available was the Garmin (and others like it) which need wires running through the firewall plus a physical switcher in the cockpit.
There are no wires through the firewall or anywhere into the cockpit; each set of lights are powered from the closest power source, front directly from the battery while the switching circuit is powered from an ignition driven Fuse #12 (I think). The rear switching circuit is powered off trailer lights power source. The system runs on a 2.4ghz Hotspot (plus bluetooth as backup) from the hotspot generated by my BlackVue Dashcam setup.
Wow! That is the coolest ever! I love doing this kind of stuff. Just never ventured into integrating truck tech with Alexa. I guess I found a new hobby.
