Removing 2" rear lift
I only removed the one side. I think if I loosened the other side I could adjusted the axel to make it slide in.
The factory lift installed uses rounded ubolts so the block on the top won’t work. With the parts needed to to make it work by removing the blocks, it’s considerably cheaper to use drop shackles. Now going that route.
Hmm. I see you're from Canada? I wonder if you guys get a different setup than we do?
I actually thought that too but then I found the kit on the US website. It's part #85877736. Maybe it's a new version? The truck's a 2025.
