PAC AP4-GM71 W/ Kicker GM Sub
The_DJH
USA
Ahoy, Recently I upgraded my front speakers and tweeters, happy but should be better. I also have the GM Kicker amp/Sub, again it's fine but should be better.
Bear with me here as I'm new to this and trying to understand.
Looking at the PAC AP4-GM71, I'd like to try it out with a suggested amp (not sure yet), but I'd like to keep the kicker sub/amp. Can I use one of the outputs from the PAC to go to the 2 wires to the amp/sub? I want to get this all coming from the PAC, as i assume that is what it is intended for.
Thank You
Yes. The Pac Amp Pro gives you a clean signal out of the factory Bose amp. This clean signal removes the filters from Bose. Run into a 5 channel (or more) amp and have a really nice system.
