Lift/level w/ new tires
Hey tboss, the kit I used includes new, upgraded UCAs which is why I chose this kit. Link below. This of course is for a 1500, so not sure what kits available for the 2500 HD. As for tires, I know the 2500 fenders allow for more rubber than the 1/2 tons, so you should be able to go 295/70r18 no problem with a 2” level, assuming you don’t replace wheels with a very negative offset. I prefer the 295/70 vs the 285/75 so you have a wider, more aggressive tire but that’s just my opinion.
Thanks and good luck!
Looks great. Question for you and MattB. I have a 2022 2500 AT4 and was looking at the 2 inch front leveling kit by Ready Lift and then adding 285x75r18s or 295x70r18s. After some research, learned that there maybe some issues with the stock UCAs down the road with this set-up. Not sure if I want to start swapping suspension parts quite yet so wanted to get your opinion on that as well as your opinion on just swapping to the larger tire size with regard to rubbing, aesthetics or anything else for that matter that I should consider. Thanks!
I don't have any knowledge with the 2500's....my apologies
