Infotainment/Radio upgrade
Check out Crutchfield. You can type in your truck details and it will show you what fits. Some differences depending on if you have the 7” or 8” screen. They have floating displays that will work and take you up to a 10” or 11” screen. You should be able to retain steering wheel button functionality, but my concern would be access to truck settings currently housed in your current in dash unit. Not sure how many setting menus you have currently in your in dash screen, but you may loose access to those setting with many aftermarket options. Need to see what settings are accessible via your cluster menu, vs what is controlled via the radio screen.
Thank you! I’ll give them a look now
Check out DONSLIFE on youtube. He has a these videos for installing a larger screen. If you search on his channel, he has other videos for larger screens.
