GM 10L80 / 10L90 / 10L60 Billet Valve Body Upgrade Kit with PulseDelete
amberkalvin
Fayetteville, NC
Military
US ARMY VETERAN
First, if there's a better place for this thread please let me know. I want to share it with everyone as I'm pretty excited to have worked this out.
So long story long, I am a dealer and purchased one of these 2020 AT4 6.2 10L80 4x4 trucks with 134K miles to retail, But I am also in the market for a truck. Of course it has the TCC shutter and crazy flare shifts between some gears, mainly everything above 5th gear. I decide to see about what the fix will be fully anticipating having to put a transmission in it and retail it or keep it with a new trans.
In all my research I come across the actual problems with these are the separator plates inside the valvebody that causes leak by and loses pressure when applying certain valves or clutches. Came across this company called NextGen Drivetrain and after a quick phone call with them they had me convinced. Did it seem like a sales pitch? It did. Just a little bit. However this is upgrading the valvebody and I could therefore keep it moving forward even with a rebuild solving future errors.
The Torque converter is often the first thing to go due to dropped line pressure from the separator gaskets blowing out or the bore not sealing perfectly against the valve. This fixes those issues so even if I have to replace the Torque converter after finding out this didn't work, the trans seemed to pull strong in every gear but did flare shift like crazy and then the tcc shudder was terrible too.
So I ordered the kit, and I dug in! I didn't start until about 3pm in the afternoon and finished wrapping up around 9 giving myself plenty of time to make sure I'm reading the directions and paying extra attention to what I'm doing. First thing and probably one of the biggest pains was just getting the exhaust out of the way. once I had the collectors loose it moved enough to get the pan off, barely. With the valve body out I simply followed instructions and took my time.
Got the valve body all put back together with the new valves, removed a couple of accumulators and a couple springs, replaced the shift valve, and voila it was moving again. I tried to top off the fluid but didn't have time. Decided to drive it home for the night (8 miles) and trans temp only got to 118. I did not get to do a relearn or anything yet as it needs to be up to operating temp (according to GM 167* or so) and it wouldn't do the relearn until it got warm enough.
Went on a drive to the middle of nowhere trying to get it up to temp, and mind you it still made some pretty crazy bump shifts and tcc shutter stuff, so I parked in a parking lot and made sure it was to temp, topped of the trans fluid (was about 3/4 a quart low still) and did the fast learn. Now in my research it showed that that can in fact solve all kinds of flare shifting, tcc stuff, you name it. So once complete (took about a minute or two) I drove it normal low throttle up to speed around 65, coasted to 15 mph. Did this 5 or 6 times. But after the 3rd time I can't even explain the feeling I had as I literally felt it shift better and better and better every time after that!
I really wanted to share with everyone because I'm a huge GM fan, I have 2 LS Swapped squarebodies, (an 89 suburban with a L83 and a 6L80, and a 74 Blazer 2wd with an LS3 and TR6060 manual) but would've never considered the 10 speed due to the nightmare trans issues I've heard about, but after learning the root cause and the fix, I would gladly own one and now I do. I am buying this truck and hope that if anyone else out there starts to have any shuddering that they look into this before the torque converter craps the bed.
Thanks for listening, hope this helps someone. Wish I took pics, but I was too concentrated on making sure I didn't mess up lol.
Link to the kit.
Haven't even detailed the truck yet, but here's a pic from auction. Came out of FL.
How did you learn the transmission yourself? Mine was acting 13 kinds of crazy and I paid the dealership to relearn it and it felt like a brand new truck again. Is there something I could do myself?
Also, with mine paid an exhaust shop to cut out the white pipe and weld in exhaust flanges on both sides of the transmission pan. I also upgraded the transmission pan to the PPE one which has a drain plug. Doing this allows me to now perform my transmission service myself and with great ease.
It ain’t the prettiest but it works awesome!
Yeah, totally doing the crossover mod in about 40K miles when I replace the fluid and filter again. I'll replace the pan then too.
For the fast learn procedure you have to have a scantool that'll access the TCM and initiate. I use a thinkcar scan tool and it has lifetime updates. works pretty well for most things.
